Activity Forums DaVinci Resolve Full Premiere Pro -> Resolve -> Premiere Pro XML Rountrip
  • Full Premiere Pro -> Resolve -> Premiere Pro XML Rountrip
    Posted by Filippo Guerra on October 26, 2012 at 10:49 am
    I’m trying to get the smoothest roundtrip between premire and resolve, via XML.
    I miss the last step from Resolve to Premiere Pro,
    that’s what I’ve done so far:
    – Edited my sequence in Premiere Pro (native C300 MXF footage)
    – Exported XML from Premiere Pro
    – New project in Resolve
    – Import XML sequence, automatically add MXF to Media Pool
    – LUTs and grading
    – Rendered the sequence (Export to FCP preset, ProRes422@1080p, individual source clips, 30 frame handles for transitions)
    Now I’m stuck. I mean, I’ve tried to export and XML from Resolve, imported in Premiere but it keeps loading the original footage…
    Please help me with the last step! 😉
    Margus Voll replied 13 years, 10 months ago 2 Members · 3 Replies
  • Margus Voll
    October 26, 2012 at 12:32 pm
    usually you need to export xml from conform page AFTER you render your separate files.
    maybe this will help ?
    Margus
    https://iconstudios.eu
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Filippo Guerra
    October 26, 2012 at 1:22 pm
    I’ve rendered the clips THEN saved the project and exported the xml to premiere.
    I’ve managed to get the right files into premiere,
    but there’s some issues with some clips that has some speed changes…
    now i’m wrapping the files in ProRes, let’s see what happens…
  • Margus Voll
    October 27, 2012 at 10:22 pm
    what kind of speed changes?
    variable speed will make things go wrong.
    most likely you have clip with no speed in the end and you need to copy paste attributes in premiere.
    just my wild guess.
    we usually grade the whole shot if not with fixed speed change i.e. variable speed shot
    Margus
    Multibridge 2 Pro
