Activity Forums Adobe After Effects fuel bar and throttle for fighter jet.
  • fuel bar and throttle for fighter jet.
    Posted by Jason Disbrow on July 10, 2007 at 10:49 pm
    How would you guys tackle this aside from brute key framing? I want to make a fuel gauge similar to what you’d see in a fighter jet. Basically the amount of fuel remaining in lbs and next to that a visual progress bar. So I’d want to start the fuel out at 1000lbs and have the progress bar filled up and when the number lowers I want the progress bar to decrease also.
    So far I’ve just used the numbers plug and keyframed the value/offset. for the progress bar I was just going to animate a mask shape.
    thanks
    Aharon Rabinowitz replied 19 years, 2 months ago 3 Members · 2 Replies
  • David Bogie
    July 11, 2007 at 6:00 pm
    Easy using expressions and a slider control.
    You must spend a few hours exploring expressions in the manual.
    bogiesan
  • Aharon Rabinowitz
    July 12, 2007 at 3:05 am
    if you chewck out the last 2 AE podcasts, it deals with creating an odometer – and while it;s not quite the same, it might help you in your task. Check it out.
    Aharon Rabinowitz
    arabinowitz(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:
    https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
