Activity Forums Maxon Cinema 4D Frontal Texture question
  • Frontal Texture question
    Posted by Will Macneil on September 15, 2005 at 9:19 am
    I’m using frontal projection to map an image onto a polygon object. While in frontal mode, the texture looks perfect, but once I generate the UVW coords, the mapping changes completely. Is this the right way to ‘freeze’ a frontal projection?
    Will
    Will Macneil replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
