Activity Forums Maxon Cinema 4D Front view rendering is not working.
  • Front view rendering is not working.
    Posted by Sally Yang on July 26, 2020 at 8:38 pm
    Hello.
    I wanted to render my work in front view. But when I change the default camera, it just shows black objects..
    I confused. How can I fix this problem?
    Sally Yang replied 6 years, 1 month ago 2 Members · 4 Replies
  • Sam Treadway
    July 27, 2020 at 1:26 am
    Did you add a light to the scene or materials with luminance?
  • Sally Yang
    July 27, 2020 at 9:14 am
    Yes I tried. But It seems the same as below image.. I don’t know what is the problem..
  • Sam Treadway
    July 27, 2020 at 12:42 pm
    It appears to be clipping through the geometry. Try setting the camera near clip to a much lower value or turn off near clipping.
  • Sally Yang
    July 27, 2020 at 9:44 pm
    Thanks! It’s working!! ☺
    I changed the clipping and moved the camera slightly back.
    It’s totally working now. Thanks!
