Activity Forums Adobe Premiere Pro from premiere to DVD/Bluray… only stereo sound?
  • from premiere to DVD/Bluray… only stereo sound?
    Posted by David Payne on February 4, 2011 at 2:08 pm
    Hi all,
    ive recently noticed all of my burned DVD’s and BluRays play in the left and right speaker of my 5.1 kit. Is there any way to putput from premiere in 5.1 and then burn the DVD or BluRay keeping this intact?
    I currently burn with TMPGEnc DVD Authoring Works.
    David Payne replied 15 years, 6 months ago 2 Members · 3 Replies
  • Ann Bens
    February 4, 2011 at 5:06 pm
    For 5.1 output from Premiere you need the Surcode-plugin.
    See audio tab in the export settings.
  • David Payne
    February 14, 2011 at 9:13 am
    thanks very much Ann,
    I can indeed see the Dolby Digital setting in the audio tab. I then get the option to choose the Dolby Digital Codec or the SurCode codec. Would you advise going for surcode then? Is there any way to set up what sounds come from what speakers or does the plugin do this work for you automatically?
    Will definitely do some tests on this when I get home to my surround sound kit but any advice in the mean time is much appreciated!
  • David Payne
    February 17, 2011 at 12:39 pm
    Ann, could you advise me on how I actually mix the 5.1 sound within premiere? I’ve got as far as adding some 5.1 tracks but how do I tell each track that for example track 1 is to be played through the left front speaker, or is that not how it works?
