from low res dnx to higher res dnx
Hi guys,
I’m usually working on short timelines so i’m transcoding high res dnx at the beginning of the editing process and working on it till te final export.
Now i have much longer project so i’va transcode it at 36DNXHD and now i want to convert it to Dnx185 for some color work.
Is transcoding the final sequence the best way doing so?
I’ve duplicated the final seq ant put it at a different bin but i am not sure if the system goes back to original footage or not.
Oren.
