Activity › Forums › Adobe After Effects › From line to text.
From line to text.
Posted by Filippo Guerra on June 12, 2012 at 6:44 amI’m trying to transform an horizontal cable wire (basically, a line) into a text.
something like this
canon someone post some tut or explanation to do this?
thanks
Amin Rodriguez replied 14 years ago 3 Members · 4 Replies -
Tudor “ted” jelescu
June 12, 2012 at 7:40 amI am sure this can be done several ways, the question is how do you want the transition to look like? Is it a morph or does the line animate to form the letters one by one? Is the file you posted the final look? Let us know and we can provide better feedback.
Tudor “Ted” Jelescu
Senior VFX Artist -
Filippo Guerra
June 13, 2012 at 6:58 amI want the wire to form the word in the middle, writing letter by letter…
the file I’ve posted It’s not the final look, i’m trying to get a continuous word, I’ll post an updated example! -
Tudor “ted” jelescu
June 14, 2012 at 6:35 amI think you can either use animated masks to ceate the illusion or use a path that you animate to form the text and apply a stroke to that. With the path it’s easier if you animate in reverse- start with the final position, draw the line with the text formed and then work backwards to unravel and flatten the line. The trick is to design a look that will allow you to have the text formed by one continuous line.
Tudor “Ted” Jelescu
Senior VFX Artist -
Amin Rodriguez
September 10, 2012 at 2:55 pmi have been looking for the same thing for about a year now… this is my problem…
https://www.youtube.com/watch?v=CIj3FmUb5eA
hope someone knows the answer.
