Activity Forums Apple Final Cut Pro Legacy from dvd to fcp needs rendering
  • from dvd to fcp needs rendering
    Posted by Pauvaccaro on October 14, 2007 at 11:39 pm
    I am dealing with FCP 5.1.4
    got the video out of a DVD with MPEGstreamclip -VOB into DV movie. Then I laid the DV segment into the sequence and… it needs rendering just to lay it out… with two red stripes (reneri nedded for both video and audio). Then I did from dvd to mpeg-streamclip quicktime movie and it still asks for rendering but only video (from two red lines got to one!) but still by laying down the vid onto the sequence it needs rendering…
    The setting in the MPEG-Stremclip where DV(DV25) for Compression, standard PAL, the audio was resampled to 48KHZ. 4:3 for aspect ratio. vid rate 25 fps
    Frame Size 720×576
    Compressor DVPAL
    Data Rate 6.9 mb/sec
    Pixel Aspect, PAL CCIR 601
    Field Dominance Lower (even)
    Audio, 1 stereo
    Aud Rate 48 khz
    , and Aud Format. 32 bit floating point
    The quicktime one (that only asks for video rendering is 16 bit for the audio format).
    FCP sequence presets DV PAL
    is there any chance I can extract the dvd clip and lay it into the sequence without the need of rendering all the time?
    thanks for any any help!!
    Rafael Amador replied 18 years, 10 months ago 3 Members · 2 Replies
  • Tom Brooks
    October 15, 2007 at 12:37 am
    Use Quicktime, not DV. The settings in Streamclip export should match the corresponding settings in your sequence. No render will be needed.
  • Rafael Amador
    October 15, 2007 at 5:46 am
    Don’t export to DV movie, because you will get a DV Sequence, the same kind of files used by IMovie.
    As Tom says export with QT and set the same parameters that you will use in your FC sequence.
    rafael
