Activity Forums AJA Video Systems From Cinewave To Kona 2..Pl Suggest Best Configuration???
  • From Cinewave To Kona 2..Pl Suggest Best Configuration???
    Posted by Harcharan Singh on November 28, 2005 at 6:11 am
    I have the following set up :
    FCP 4.5
    G5 DUAL 2 GHZ WITH 2 GB RAM
    ATTO UL4S CARD WITH MEDEA RTRX DISK ARRAY
    Cinewave 4.7 RT
    We want to upgrade our system with Kona HD 2 and want suggestions from you guys so that we can work also in HD uncompressed in future for FILM editing.
    Thks
    Harcharan
    Walter Biscardi replied 20 years, 5 months ago 4 Members · 5 Replies
  • Walter Biscardi
    November 28, 2005 at 1:13 pm
    [Harcharan] “We want to upgrade our system with Kona HD 2 and want suggestions from you guys so that we can work also in HD uncompressed in future for FILM editing.”
    Remove the CineWave card and all drivers. Deposit in the nearest trash bin.
    Install Kona 2 with K-Box. Download all latest drivers from the AJA website and install.
    Begin editing.
    The RTRX supports uncompressed HD as I’ve done tests with my old 1440 unit in the past, but I don’t think it will work with the single channel SCSI card, it needs to be dual channel. I run Fibre Channel now (FCR2X) and it’s amazing.
    I switched from CineWave over a year ago and Kona 2 is a very easy transition. You just need to read up on how the Control Panel works as it can control video I/O independent of FCP. It’s also where you set up the hardware Up / Down convert.
    Walter Biscardi, Jr.
    “The Rough Cut,” an original short film premiering December 7th in full High Definition in Atlanta.
    rsvp@biscardicreative.com to reserve seats.
    https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • David Battistella
    November 28, 2005 at 9:10 pm
    Easy with the SHOUTING THERE MAN!!!
    David
    [Editor’s note: Please don’t use all caps in subject line, as I’ve had to change it.]
  • Ron Thompson
    November 29, 2005 at 3:57 am
    If you are looking to work in HD in the FUTURE but are doing SD now, consider two things:
    1) KonaLH will allow you to bring in SD as well as HD…almost mirrors a Cinewave setup without the extra BOB.
    I’ve always looked at the Kona2 as a “hardcore” HD solution with some SD perks. If you don’t do HD now, you might consider the LH card.
    2) if you go with the Kona2, you will need an IO box to get analog into your system.
    Otherwise, you’ll be very happy with the Kona…whatever you get.
    Good Luck
    Ron
    Dual 2Ghz, UL4D, Huge MV1200, MedeaRTR 1GB, FCP5
  • Harcharan Singh
    November 29, 2005 at 10:12 am
    Hi guys,
    Thanks for your replies and sorry David for all caps in the post topic.Just a question will Atto UL4d work with Medea RTRX for HD uncompressed.
    Harcharan
  • Walter Biscardi
    November 29, 2005 at 12:32 pm
    [Harcharan] “Just a question will Atto UL4d work with Medea RTRX for HD uncompressed.”
    Yes, but at the time I tried it, I had all kinds of problems with their drivers. I ran my RTRX with the 3D with no problems at all. This was about 6 months ago or so, so I’m sure the drivers are better now.
    Ron’s suggestion of the Kona LH is a good one to look at as well if you don’t need SD to HD Up-Convert or the 4:4:4 I/O.
