Activity Forums Adobe Media Encoder from 1-2 hour export times to 10+ hour export, 15 min file.
  • from 1-2 hour export times to 10+ hour export, 15 min file.
    Posted by Greg Burke on October 11, 2013 at 6:27 am
    Hey guys so I’m exporting a .mov from CS6 the Raw footage is h.264 1080, I added 2 filters Fast color correction, and Three way color, I have a Jpeg on the timeline over the footage as well. I’ve exported allot of these things, they mostly all take the same amount of time 1-2 hours for a 15min long output, However this time its taking 10+ hours? this doesn’t make sense to me at all, any help? Below are the RAW and Export Settings
    RAW
    Canon 5D Mark III (H.264, 1920×1080, 24fps)
    Output
    1920×1080
    H.264
    VBR, 2 pass, Target 5.00 Mbps, Max 6.0 MBps
    AAC 192, 48hz
    Thanks in advance!
    CS6, Mac OsX
    2.26ghz quad core 16gigs RAM
    I wear many hats.
    http://www.gregburkepost.com
    Greg Burke replied 12 years, 11 months ago 2 Members · 3 Replies
  • Ivan Myles
    October 11, 2013 at 10:58 am
    First verify whether GPU acceleration is enabled. Second, did you enable Maximum Bit Depth or Maximum Render Quality in the export settings?
  • Greg Burke
    October 11, 2013 at 8:22 pm
    Well, I’ve exported a ton of this sequences prior,and haven’t had this problem until now, and No Maximum Render Quality isn’t on. I don’t have a Nvidia Card I have a AMD card so no acceleration for me.
    I wear many hats.
  • Greg Burke
    October 11, 2013 at 10:48 pm
    I actually figured out the problem, I had taked CR2 images and saved them as jpgs, but I didn’t change the resolution which was about 3500×4500, and CS6 was having issues rendering it out.
    I wear many hats.
