Activity › Forums › Adobe After Effects › frm ae to premiere
  • frm ae to premiere
    Posted by Aroonzfx on August 14, 2005 at 5:58 am
    hi
    i had to export a project frm premiere to ae
    i could import the premiere project and work freely
    but the problem is what is to be done to get the same opened in premiere…
    i dont want to render it as mov or so as it may lead to a slight loss…
    can i open the ae edited proj or aep in premiere ??
    what is the reverse process ???
    i feel that i dont need to render it to a mov or avi file ..but instead i am missing something to get the same ae edited sequence back in premiere
    looking forwared for ur help
    thanx
    aroonz
    Aroonzfx replied 21 years, 1 month ago 2 Members · 2 Replies
  • Michael Duff
    August 14, 2005 at 10:44 am
    I believe you will have to render. AE has different features that Ppro doesn’t understand so simply importing the AE file doesn’t work.
    If you render as a quicktime with animation codec you shouldn’t have any quality loss and the files will be smaller than uncompressed.
    Make sure your interlacing is common everytime you import/export so that the field order doesn’t get mixed up.
  • Aroonzfx
    August 14, 2005 at 5:25 pm
    thanx a lotttttttttt
