Activity Forums Apple Final Cut Pro Legacy FREEZZE FRAME ISSUES!!!
  • FREEZZE FRAME ISSUES!!!
    Posted by Carmello on August 10, 2007 at 4:21 pm
    hello Boys!
    HOPE I Can get some genius feedback. I am cutting FCP 8-bit footage and have 2 freeze frames happening. On the computer monitor the freeze frames are great, clean and do not jitter. They look good. But when I master a DVD in DVD studio pro, and watch on the television, the freeze frames have scan lines and jitter. I already set the dvd inspector to bottom first for fields cleaning up the jitter throughout the video, but these freeze frames still have scan lines and jitter. Is this a deinterlacing issue?????
    Any comments would be greatly appreciated.
    Shane Ross replied 19 years, 1 month ago 2 Members · 1 Reply
  • Shane Ross
    August 10, 2007 at 4:25 pm
    YUP…deinterlacing issue. If you are working with interlaced footage then when you make a FREEZE FRAME, you need to add the de-interlace filter.
    Another GREAT example of why an external NTSC monitor or TV is a requirement when editing…so you can see what you REALLY have going on in your cut.
    Shane
    Littlefrog Post
    http://www.lfhd.net
