Activity Forums VEGAS Pro Freezes while rendering
  • Freezes while rendering
    Posted by Anders Fougner on October 28, 2008 at 3:24 pm
    No matter what I try, the rendering freezes at about 2%.
    I’ve tried changing the clip that’s on 2% (didn’t work), I’ve tried pre-rendering (nope) and I’ve also tried tons of different rendering settings (no worky).
    It’s extremly annoying! I’m trying to render a movie containing 30 min of AVCHD footage and about 3 shots with a normal SD miniDV camcorder.
    My computer has Windows Vista (32-bit I quess), and 4gb ram, so I don’t see the problem really… Never had this type of trouble before!
    If you help me out, I will give 100 dollar to the poor, not kidding!
    Dale Spetz replied 17 years, 10 months ago 4 Members · 9 Replies
  • 9 Replies
  • Anders Fougner
    October 28, 2008 at 10:25 pm
    Nobody? I am desperate!
    If this forum has karma I’ll give you tons of it if you give me some advice!
  • Steve Rhoden
    October 28, 2008 at 10:30 pm
    What version of vegas are you using?
    Probably you can try converting those AVCHD files in
    another application, then drop them in vegas to edit,
    because it seems as if its the AVCHD files that is
    causing the trouble.
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
    sample bits at
    http://www.youtube.com/hentys
  • Steve Rhoden
    October 28, 2008 at 10:37 pm
    Try updating to version 8.0b or 8.0c…restart and see if
    things run smoothly then.
    Remember, updating is free.
    Steve Rhoden
    Creative Director
    sample bits at
  • Anders Fougner
    October 28, 2008 at 10:40 pm
    Thanks, but this would be a little difficult, since I’ve allready finished my entire project!
    I’m working with vegas 8.0a, but as I said, I never had these problems before!
  • Anders Fougner
    October 28, 2008 at 10:46 pm
    Ok, will do and come back with results!
  • Anders Fougner
    October 30, 2008 at 10:54 am
    So now I’m in version c build 260 (i think)
    still not workin..
    any ideas whatsoever?
  • Anders Fougner
    October 30, 2008 at 11:01 am
    But the problem is a little different now, the program just shuts down when it done rendering the first two shots..
  • Douglas Spotted eagle
    October 30, 2008 at 3:07 pm
    Anders,
    look for these things (apologies if Steve covered them, I’ve not read every one of the posts;
    ~Be sure no antivirus is running. Kill ALL background apps.
    ~If using an external USB drive, consider using Firewire instead.
    ~If rendering to MPEG, watch your CPU heat. This kills renders more often than you’d think.
    ~I can’t see the format you’re rendering to in the thread. Knowing this might help.
    ~kill video preview/drawing frames while rendering.
    These are all “first look” things when rendering fails.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Dale Spetz
    November 1, 2008 at 2:45 pm
    If you haven’t done so, I have also found it helpful to split Source, Destination and OS/Vegas onto seperate Hard Drives.
