Activity › Forums › Apple Final Cut Pro Legacy › Freeze the to first frames when editing to tape using decklink multibridge extreme
  • Freeze the to first frames when editing to tape using decklink multibridge extreme
    Posted by Thomas J. m on April 4, 2006 at 1:26 pm
    Hey there
    When i Edit to tape in Final Cut pro 5 i have this problem that it freezes the first frame and playing it twice, This meen that if i have a cormercial that is 30 seconds long and i want to put it on tape at timecode
    00:02:00:00 then it puts the first frame twice on 00:02:00:00 and on 00:02:00:01 and then it plays from there. This now meens that the cormercial is done at 00:02:30:01 and not on 00:02:30:00.
    Is there annyone out there that knows how to fixe this, can i offset it in anny way or fixe it.
    My system
    Dual-core 2.5GHz PowerPC G5 processors, med decklink multibridge extreme and Final Cut V5
    I am mastering out on a Digibeta using SDI with embeded Audio and RS422 controling.
    Thank You
    Thomas J. Mikkelsen
    Editor, Frontier – Denmark
    Emer replied 19 years, 9 months ago 2 Members · 1 Reply
  • Emer
    December 18, 2006 at 6:02 pm
    I have the very same issue, all my edit to tape sequences start with a freezeframe, and then everything is off by 2 frames. I also have the exact same set up. Anyone out there have the solution?
    Emer
    Dublin
