Activity Forums Apple Final Cut Pro Legacy Freeze frames losing filters
  • Freeze frames losing filters
    Posted by David Scott on March 20, 2009 at 4:17 pm
    Hi Folks
    Found a few posts about this but no-one seemed to have a solution, so thought I’d try again just in case, in the intervening months it’s been cracked….
    If I make a freeze frame from the start of my 5 min clip it’s fine, if I make one from the end the filters have disappeared! If I try copy and paste on the filters the vignette is wrong as I’d zoomed the shot. I know I can export a TGA and re-import but it takes longer and messes up future reconnect options.
    Anyone found the fix for this one?
    David Scott,
    Senior Editor,
    GOD TV (UK)
    David Scott replied 17 years, 6 months ago 2 Members · 3 Replies
  • Jason Diebler
    March 20, 2009 at 8:56 pm
    Are you using the “Modify > Make Freeze Frame” to make your still? If that’s not working like you say, try “Export > Using Quicktime Conversion > Still Image”, import, and see if that works.
  • David Scott
    March 20, 2009 at 9:04 pm
    Hi Jason
    Yes the export option works fine – just takes longer!
    It’s very strange as you can make a Freeze Frame (shift N) from the start of the clip at any point up to about 1/3 of the way along and it keeps the filter effects but then past that point to the end it losses the filter information!
    Cheers
    David Scott,
    Senior Editor,
    GOD TV (UK)
  • David Scott
    March 22, 2009 at 4:36 pm
    Hi
    A further intersting point….
    When exporting a still I noticed a slight change in the highest luma values, with them being slightly clipped, even though they were broadcast safe on my external scope. So I found that exporting 1 frame as a QT and then re-importing it and puting it on the timeline with a speed of 0 worked a treat!!
    However still very interested to know why the FCP freeze frame loses filters if anyone does have any insight…
    Cheers
    David Scott,
    Senior Editor,
    GOD TV (UK)
