Activity Forums Adobe After Effects freeze frames in AE
  • freeze frames in AE
    Posted by Paul Nevison on May 25, 2007 at 3:41 pm
    hey there
    a quick AE newbie question.
    I’m using some paint splatters and I want to freeze frame the splatters after they animate on. I’ve tried using the freeze frame function but it makes the whole clip a freeze frame as opposed to freezing once the animation comes to an end.
    I know this is easy to do….trying to get my brain into AE thinking takes a little longer than when I’m editing.
    thanks
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    BMD Decklink Extreme 6.0
    PAL Land
    Ronaldo Montalvo replied 19 years, 4 months ago 4 Members · 4 Replies
  • Kevin Camp
    May 25, 2007 at 3:47 pm
    time remap should do it… enable it in the layer>time menu, then add a keyframe to the time remap propperty at the point where you want to freeze and delete the keyframe at the end of the property.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Paul Nevison
    May 25, 2007 at 3:58 pm
    No my editor definetly does freeze frames 🙂 just getting my head around how AE does it…new apps with new workflows that’s all.
    thanks for your help…..using a new app sure makes you feel dumb!!!
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    PAL Land
  • Jason Sanders
    May 25, 2007 at 6:05 pm
    you have a couple of options inside of AE:
    1. File>”Save frame as” and then reimport it.
    2. Use timeremap to set a still frame from video
    3. Right click on footage (when at point where freeze frame is intended) and choose time>freeze frame-*note*-I believe this option is only available in AE7 or greater.
    Hope this helps.
    Jason Sanders
    http://www.hecticfilms.com
  • Ronaldo Montalvo
    May 25, 2007 at 8:32 pm
    “thanks for your help…..using a new app sure makes you feel dumb!!!”
    nope, that’s what dave is here for. 🙂
