Activity › Forums › Avid Media Composer › Freeze frame push ins with a tilt
Posted by Hunter on February 15, 2006 at 7:04 pmHow do you do a push in and a half circle camera twist on a still in the timeline?
thanksSatesh Ramjattan replied 20 years, 7 months ago 3 Members · 3 Replies -
Abransford
February 15, 2006 at 7:12 pmIf you have the title on the timeline, simply go into effect mode and promote the element to 3D using the button on the lower right-hand corner of your effect control window. From there, you can do all sorts of 3D DVE effects. Hope that helps!
Hunter
February 15, 2006 at 10:18 pmI opened up the effects window and their are no active buttons to promote to 3-D. I’m not quite sure how to do that. But you said title and this is just a Freeze frame of a video clip that I made using the Freeze frame option under the clip menu. Can you elaborate please.
thanks -
Satesh Ramjattan
February 15, 2006 at 11:13 pmjust pop “3D pip” effect and take it from there. it scales the image down 50% by default, so just keyframe how you want.
