Activity › Forums › Apple Final Cut Pro Legacy › freeze frame problem
  • freeze frame problem
    Posted by Adam Taylor on June 14, 2007 at 3:44 pm
    Any able to shine any light on this problem??
    I have a shot that i need to freeze that comprises of 5 video layers…2 graphics layers (animation + alpha) and 3 video layers (uncompressed 10bit pal).
    I have render the shot and then created a freeze. When its edited onto the end of the shot there is a very definite drop in the video levels. The freeze has not been deinterlaced either and visually you can tell that both fields are playing.
    Its most noticeable on the animation – there is a logo with a bright yellow “flaring sun” particle effect behind it that just drops its brightness on the freeze.
    Its got me baffled – any ideas?
    Adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
    Adam Taylor replied 19 years, 3 months ago 4 Members · 9 Replies
  • 9 Replies
  • David Roth weiss
    June 14, 2007 at 3:49 pm
    Adam,
    If you color corrected the underlying footage the color correction does not automatically find its way into the frezze frame, you must copy it to the freeze frame.
    David
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Adam Taylor
    June 14, 2007 at 3:53 pm
    Hi David,
    no – no colour correction on any of the tracks. 1 video track has a gaussian blur, and the two graphics tracks use 4 point garbage mattes but those are the only treatments used.
    adam
    Editor/Mixer
    Oldham, UK
  • Adam Taylor
    June 14, 2007 at 3:55 pm
    looking at the problem through a scope – it looks like the gamma drops by about 5% between the video and the freeze.
    adam
    Editor/Mixer
    Oldham, UK
  • Rafael Amador
    June 14, 2007 at 4:33 pm
    Hi Adam,
    I don’t know if could work but I would try nesting the sequence and droping a de-interlacer after the freezing. BTW which codec is your time-line?
    rafael
  • David Roth weiss
    June 14, 2007 at 5:14 pm
    [lightning ad] “1 video track has a gaussian blur”
    My point was that you need to copy whatever filters you applied to the freeze frame too…
    David Roth Weiss
    Los Angeles
  • Adam Taylor
    June 14, 2007 at 10:37 pm
    David, i see what you mean…i shall try that.
    Rafalaos, i’ve tried the nesting and it made no difference. the timeline is 10bit uncompressed 422 pal.
    I think the easiest way, although it doesn’t solve the underlying problem, is to digitize the material out to digibeta, re-digitize it and do a freeze on the new import. That is something i have had to do in the past and works perfectly everytime!!
    adam
    Editor/Mixer
    Oldham, UK
  • Neil Ryan
    June 14, 2007 at 10:47 pm
    When you tried ‘nesting’ where were the filters?
    I’d try nesting the clip and its freeze only, then apply the filters to the nest. That SHOULD work …
    (It’ll be quick to do if use the copy & paste attributes functions – you won’t have to recreate any filter effects.)
    let us know.
    Neil.
    Neil Ryan
    Post Production
    The Pod Multimedia
    http://www.the-pod.com.au
  • Adam Taylor
    June 15, 2007 at 12:15 am
    the trouble is there are no filters in use. The bottom track has gaussian blur – but track is only visible at the extreme edge of frame, to hide a reframing issue caused by repositioning an old packshot for new brand graphics.
    the only other filters are two 4pt garbage mattes. I can’t see how they could cause the problem
    rgds
    adam
    Editor/Mixer
    Oldham, UK
  • Adam Taylor
    June 15, 2007 at 8:14 am
    Doh!!
    i have found the cure!!
    it seems when i selected the offending tracks and told FCP to “Render only… needs render”, it was not rendering the freeze but leaving it in a preview state.
    Forcing a full render of all video cures the problem.
    Thanks for all the suggestions.
    adam
    Editor/Mixer
    Oldham, UK
