Activity Forums Apple Motion Freeze Frame, Pause in motion
  • Freeze Frame, Pause in motion
    Posted by Smoothe271 on August 18, 2006 at 7:20 pm
    Is there a way you can put a freeze frame from the video in motion. Or do I have to export an image every single time on Final Cut to work with it.
    Adolfo Rozenfeld replied 20 years ago 2 Members · 1 Reply
  • Adolfo Rozenfeld
    August 21, 2006 at 2:25 am
    You can easily do this in Motion. Select the Object and then go to the Media tab in the Project palette (Hit Command-4 or the “Project” button if not already visible). Select the thumbnail related to your image (again, in the Media tab, not the Layers tab) and then go to the Inspector. It will show the different interpretation and timing behaviors of your source footage. Set the Start and End frames to the frame you want and then set the End Condition to “Hold”. You can now alter the duration manually in the timeline for your frozen image.
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    https://www.adolforozenfeld.com
    adolfo(AT)adolforozenfeld.com
