Activity › Forums › Avid Media Composer › freeze frame greyed out – might be a bug
  • freeze frame greyed out – might be a bug
    Posted by Mr Dirden on February 24, 2013 at 9:40 pm
    Hey,
    After quite a few questions I’ve posted, I’m writing now in order to document on the web a problem which I’ve discovered – me myself could not found the essence of the problem while searching on the web, so I’m documenting.
    I had a problem with Freeze Frame which is greyed out – couldn’t click on it, although I was in the source monitor. Match frame didn’t help, and suddenly I’ve discovered that I can’t do a freeze from any clip in my project.
    To make a long story short, after a lot of trying I found out that the problem was in the fact that I’ve modified all of the clips to stereo, so that I could work in stereo channels. Wiser now, I could do a better google search, with which I found out that MC had a bug with freeze frame from stereo clips. This bug was solved in MC 6.0.3. Couldn’t think of the connection to the stereo before I found that this was the problem, because I had no mono clip in my project, so I thought the problem was in the project or the materials or the combination of both.
    So if you find yourself not able to make a freeze frame from stereo clips in an older MC than 6.0.3, and not knowing why, it’s just a bug. Remodify audio channels, make that freeze, than modify again.
    Cheers.
    Mr Dirden replied 13 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
