Activity Forums Apple Final Cut Pro Legacy Freeze Frame Flickering??
  • Freeze Frame Flickering??
    Posted by Danny Boyee on August 20, 2005 at 1:00 pm
    My freeze frame looks fine on the canvas but on the monitor the whites are just flickering away. I ‘ve never had this problem on any other projects. I’m wondering if a gaussian blur would help or what could be done to calm this down.
    Thanks DB
    Matt Sandström replied 21 years, 1 month ago 4 Members · 3 Replies
  • Andy Mees
    August 20, 2005 at 1:05 pm
    Hey Danny
    If you haven’t already done so, you might want to check your levels against the the scopes. Press Option 9 to bring up the scopes, and make sure your white level is not exceeding 100% … use either the color corrector, broadcast safe, proc amp or levels to bring them down if necessary.
    Cheers
    Andy
  • David Roth weiss
    August 20, 2005 at 6:34 pm
    Or, it could be that you’ve chosen a frame with too much motion bewteen fields. FCP toggles between fields on still frames and this only shows on an NTSC monitor, not VGA monitors. Try choosing a slightly different frame that is “quiet” when you park your cursor on it in the timeline.
    DRW
  • Matt Sandström
    August 20, 2005 at 6:48 pm
    or deinterlace it of course. or blend fields. or “reduce flicker”. check out my plugins (https://www.mattias.nu/plugins/) for better versions than the built in options.
    /matt
