Activity › Forums › Apple Final Cut Pro Legacy › Freeze frame artifacts
  • Freeze frame artifacts
    Posted by Leonard Frankford on February 28, 2012 at 5:40 pm
    I am making freeze frames for a project and when I drop the frame into the sequence, render and then playback, there is a blocky artifact on playback. When you pause the playhead it looks OK, but as soon as I play the clip I see blockiness and extra chroma on the highlights. I’ve even tried exporting where the playhead lands as a still image/png and bringing it back in, but I get the same results. Has anyone seen this before? Any ideas? Thanks.
    Leonard
    Leonard F.
    Leonard Frankford replied 14 years, 7 months ago 2 Members · 4 Replies
  • Stephen Smith
    February 28, 2012 at 9:05 pm
    Try de-interlacing the still grab and see if that works.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Leonard Frankford
    February 29, 2012 at 1:33 pm
    How do I deinterlace? I don’t see it under any of the video filters.
    Leonard
    Leonard F.
  • Leonard Frankford
    February 29, 2012 at 1:54 pm
    I found the smart de-interlace. It didn’t help.
    Leonard F.
  • Leonard Frankford
    February 29, 2012 at 2:58 pm
    The de-interlace didn’t help but it turns out the problem was that FCP was using a Sorenson 3 compressor for the sequence (these were strange .mvp video files to begin with). When I switched over to the DV compressor and rendered, the stills were fine–didn’t even need de-interlacing. Thanks.
    Leonard
    Leonard F.
