Activity › Forums › Adobe After Effects › FreeForm Misaligned with other 3d Layers
  • FreeForm Misaligned with other 3d Layers
    Posted by Clive Barry on June 12, 2016 at 12:23 am
    Hi there,
    I’ve found to my chagrin that Mettle FreeForm does not match up with any other 3d layers in the same composition if I move the camera. It will respond to the camera, but in a manner wildly misaligned from the rest of AE 3d space… is this normal??
    Many thanks for your help
    Clive
    Clive Barry replied 10 years, 3 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    June 13, 2016 at 7:35 am
    No, it is not. The integration should be flawless. The one thing I can think of is if your other 3d layers/objects are positioned before you create the FF layer. You need to position the FF object in 3d space using the plugin controls to match the x,y,z of the plane you are trying to match it up with. It may be that you need to reset position on all layers to “0” and re-position everything again.
    Tudor \”Ted\” Jelescu
    Senior VFX Artist
  • Clive Barry
    June 30, 2016 at 12:23 am
    You are entirely correct — had the freeform layer set as a 3d layer… ordure for brains!
