Activity Forums Adobe After Effects Freeform and 3D Mapping? Are they good bedfellows?
  • Freeform and 3D Mapping? Are they good bedfellows?
    Posted by Jason Mckee on May 21, 2010 at 10:19 pm
    Is it possible in AE CS5 to use the new DigiEffects plugin Freeform to create a 3D landscape that can then have footage 3D Camera mapped to it? I wouldn’t want to have to precomp it ahead of time since this would make the Freeform layer appear as a 2D plane. Any ideas? Thanks in advance.
    -jm
    Jason Mckee replied 16 years, 3 months ago 33,870 Members · 2 Replies
  • Jason Mckee
    May 24, 2010 at 9:30 pm
    sorry I’m not sure if I explained myself clearly. I essentially want to do this:
    https://www.videocopilot.net/tutorial/3d_camera_projection_2/
    but with 3D Camera projecting onto a 3D mesh as opposed to a 2D plane which is actually closer to this:
    https://www.3dfluff.com/cameramapping/cameramappingtut.htm
    I’m just curious if I would be able to use Freeform to create the mountains in the distance like in the second example. thanks.
    -jm
  • Jason Mckee
    May 24, 2010 at 11:35 pm
    Yeah you re definitely limited to Z space movement and just a tad bit of X and Y movement but it can be a pretty cool technique. I know they used this technique quite a bit in Avatar when creating the wide shots of the vast terrain:
    https://media.fxguide.com/fxguidetv/fxguidetv-ep082.mov
    Within the first 15 seconds of this video you can see how WETA (using Nuke) just created a matte painting and then 3D Camera projected that image onto a 3D mesh to give them some realistic 3D paralax by adding a slight 3D camera move to the scene.
    haven’t tried it yet but I was just curious if After Effects now, by using Freeform can essentially do the same thing.
    -jm
