Activity Forums Adobe After Effects Expressions frames from pre comp
  • frames from pre comp
    Posted by Jack Parks on October 20, 2008 at 4:11 pm
    does any one know an expression that does the following…
    [I thought I had seen one somewhere to generate storyboards from clips]
    A video clip is in a pre comp.
    In the main comp drag the precomp and the expression would show a still frame,
    this layer is duplicated and each shows a different still frame either from typing a specific value
    or relating to its layer number (layer 1 shows frame 1, layer 2 frame 2 etc)
    Hope this makes sense.
    Jack Parks replied 17 years, 10 months ago 3 Members · 5 Replies
  • Darby Edelen
    October 20, 2008 at 4:17 pm
    The only way I can think to do this would involve time-remapping and doesn’t require that you pre-comp your footage (unless there layers other than your footage involved). Apply this to the time re-map:
    framesToTime(index);
    And that should do it assuming that the footage layers in your main comp start at index 1.
    Darby Edelen
  • Jack Parks
    October 20, 2008 at 4:28 pm
    Thanks for your help, I will try it.
    Thanks again.
  • Jack Parks
    October 22, 2008 at 10:49 am
    Hi, is there a way to adjust the expression, so the layer order is reversed?
    This way the layer above would be the next frame.
    Thanks.
  • Dan Ebberts
    October 22, 2008 at 1:06 pm
    Something like this:
    framesToTime(thisComp.numLayers – index)
    Dan
  • Jack Parks
    October 22, 2008 at 1:27 pm
    That works great.
