Activity Forums VEGAS Pro Framerate worry in Sony Vegas
  • Framerate worry in Sony Vegas
    Posted by Max Roy on August 15, 2010 at 9:00 pm
    Hey guys,
    Since I’m using Sony Vegas to edit right now, I thought this would be the best place to post.
    My problem is that I’m trying to put a 1920×1080 23.976fps h264 video in that m2ts format (Using tsMuxeR) so I can edit it in Sony Vegas. It works fine, there seems to be no problems, I can edit it fine in Sony Vegas, and there seems to be no playback problem.
    My only worry is that I tried to keep close to the original source by picking 24fps as framerate (when using tsMuxeR to put the h264 in m2ts format) and when outputted the m2ts file shows up as 48fps. Is this a problem, why does it do this? I tried the other choices of framerates in tsMuxeR and they all double except for 24000/1001 which gives me around 487000fps (woah! haha).
    Is there a fix? Or is the 48fps not a problem as long as I render back to the original source (23.976) when I’m done editing in Sony Vegas? It would go 23.976(original h264) > 48(m2ts) > 23.976(Final Render). I want to keep the best quality I can with no jerking motion that would be displeasing to the eye.
    Thanks much in advance for any help anyone can provide.
    Brandon Smits replied 16 years ago 2 Members · 1 Reply
  • Brandon Smits
    August 18, 2010 at 9:59 pm
    Max,
    I’ve been watching this thread for the past 3 days hoping someone could help you who is familiar with vegas. I’ve been editing on Final Cut for 10 years, and have dealt with crazy workflows extensively. I wanted to ask you whether the footage was progressive or interlaced. I suspect(someone tell me I’m wrong if you know otherwise) that your footage is being converted from progressive to interlaced explaining the doubling in frame rate. I’m also not familiar with tsmuxer, but I’m at the very least trying to get a dialogue going so you can solve your issue.
    8core Mac Pro Early ’08 Xeon 2.8 14gb RAM
    Apogee Ensemble
    JBL LSR 4328 Surround Set up
    Euphonix Artist Series Mc Control, Mc Mix, Mc Transport
    All wired with Mogami Cable
