Activity Forums Maxon Cinema 4D Frame step of animated random movement
  • Frame step of animated random movement
    Posted by Pravin Chottera on July 13, 2015 at 10:05 pm
    I was wondering if there was a way to have the animated movement of the random effector be “steppy”, by which I mean have the clone move for one frame, stay for a few frames, and then jump again. I basically want the opposite of smooth movement and want something very jumpy and frenetic.
    Thanks everyone!
    Adam Trachtenberg replied 11 years, 2 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    July 13, 2015 at 11:45 pm
    Here’s one way you could do it:
    * Key the random effector’s seed parameter. Then move the timeline to (for example) frame 10. Increase the seed parameter by 10, and key again;
    * Select the random effector in the timeline and run Functions>Bake Object with only “Parameters” checked. Set the end time to frame 10;
    * Select all the keys and set the interpolation type to Step;
    * Scale the key selection to the length of your animation.
