Activity › Forums › Apple Final Cut Pro Legacy › frame skipping in QT Mov.
  • frame skipping in QT Mov.
    Posted by George Sloan on January 29, 2011 at 1:39 am
    Just saved a 3o minute program QT Movie(with compression markers) everything looks great except for occasionally skipping a frame or 2. Will this correct when I export to compressor? What could be happening?
    George Sloan
    sloanmotion.com .. FCP7,Leopard, Dual Core, Mac Pro 2.66mhz final output to
    ProRes>QTM>Compressor>SD-DVD down convert>forDVDF distribution/Broadcast
    George Sloan replied 15 years, 8 months ago 2 Members · 2 Replies
  • Jeff Greenberg
    January 29, 2011 at 7:35 pm
    Yes, it’ll be fine.
    QuickTime is a playback engine, but it’s also a container. There are a number of codecs that aren’t optimized for playback through QuickTime, but QuickTime still holds all the frames. When it gets to compressor, it’ll access each frame for further compression.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • George Sloan
    January 29, 2011 at 10:22 pm
    Jeff G,
    I worked until 3AM last night trying to figure that out!
    I was beginning to think I had asked asked a dumb question.
    You are my Hero. Need more like you.
    George
    George Sloan Productions
    http://www.sloanmotion.com
    “Music Mountain” Channel 4 Windstream Cable TV
    Cannon Xh A1 1080i>FCP7/ProRes>SD DVD>For Delivery to Broadcast and DVD distribution
