Activity › Forums › Adobe Premiere Pro › frame size(premiere pro 2)
Posted by Arthur489 on August 22, 2006 at 4:25 pmGood morning,
I’ve a clip wich is 320 X 240,how can i adjust my frame size?(I tried with the progect setting,but all the option haves frame of 720 X 480 )do I’ ve to use the crop effect or is there another way to have my frame match the frame of the clip?(320 X 240)
Thanks in advance.
ArthurSheila Eubanks replied 17 years, 2 months ago 5 Members · 5 Replies -
Tim Kurkoski
August 23, 2006 at 4:42 pmThe big question here is what is your output from Premiere going to be?
If you’re going to output to DV, DVD, or other standard video formats, use the 720×480 frame sizes and scale the clip up to cover the whole frame.
If you’re planning to output back to 320×240 for the web or iPod or other computer-based formats, you can customize your project settings. In the New Project dialog, click the Custom Settings tab. Set the Editing Mode to desktop, then you can change the Frame Size dimensions. Also change the Pixel Aspect Ratio to Square Pixels (unless for some very bizarre reason you have a non-square pixel 320×240 clip).
Arthur489
August 24, 2006 at 1:31 amthank you very much for the answer.I will need to use both setting,and your answer is very helpfully and complete.I apreciate.
best regards
Arthur -
Jmc1985
September 23, 2006 at 3:21 pmHello, I have a problem related:
What can I do if I’ve finished my project in 720×480 and now I realized that I need to have a 320×240?My original clips are 320×240 and this problem creates a black frame around the clips.
Can I change the settings without repeating all the project?
Is there any option to export/move all the edited clips (or timeline) to a new project with new settings?A lot of thanks and sorry for my possible english mistakes.
Rob Glenister
January 3, 2008 at 12:12 pmI would like to create an AV using a number of stills 1026 x 686. Can I set the custom frame size to this size and what effect will it have?
Sheila Eubanks
July 8, 2009 at 2:14 pmMy editing mode selection is blacked out what do i do to fix this
