Activity Forums Adobe After Effects Frame shift of two comps. Why???
  • Frame shift of two comps. Why???
    Posted by Katherine Landgrebe on November 18, 2009 at 10:26 am
    Hi, maybe I’m just blind, but…
    I have two compositions. Both have 24fps, both are 2 minutes in length. One is placed into the other.
    But: When I place the timeline-thingy to, say, 1 minute in the subComp, it’s at 1:06 in the main comp. Also the values of my expression that I use in the SubComp are shifted timewise 2 frames/second. So, I lose the synchronization, and at the end of 2 minutes, I have 12 seconds difference. I did not use time remap.
    What can this be?
    P.S.: I just tried out a copy of the SubComp, this one is perfect. Strange, strange, strange.
    Katherine Landgrebe replied 16 years, 10 months ago 59,901 Members · 4 Replies
  • Katherine Landgrebe
    November 18, 2009 at 2:17 pm
    Thanks, Dave, for your response.
    I forgot to mention, that there is no original video footage in my project. It’s an AE animation, the only thing I imported are Illustrator files. So, it’s a FullHD 1920×1080 composition in HDTV, 24 frames. I set them all up like this, but I always get confused with all these standards. I used that one that AE has as a preset in the comp-preferences.
    November 18, 2009 at 6:47 pm
    Well, for I’m more a designer than a technician, I’m not too familiar with each and every detail of all these things. Sorry about that. I try do do my very best to get it right. Thanks for your suggestions.
    I set this project up for myself, first of all (free study project). I’m gonna burn it on BluRay later and show it as a QTmov from my computer. If I’m lucky, it’s shown on festivals in movie theaters in Germany or somewhere else in Europe. Then there will be a PAL DVD in 25 frames as a preview version. Then there will be a NTSC DVD for non European film festivals. Then there might be a BetaSP PAL tape for broadcasting. You see, I have to set something up and change it later anyways. I can’t build 3 different versions, I have to re-render it.
    The 24 frames may be wrong, and I promise, my next project will be in 23.976. 🙂
    If I did it wrong, I have to live with it for now or change my project carefully step by step, but actually, I did not use different frame rates in one project. I double-checked it all, it’s all set to 24.00. Anyways, which frame rate ever I use, inside the project it should be synchrone when two comps have the same frame rate, shouldn’t it?
    I might just switch to 25fps, then at least Europe is happy 🙂
    November 18, 2009 at 7:25 pm
    >>My compliments on your excellent English, by the way.<<
    Haha, thanks. I studied in the US for a (way too short) while.
    Yep, I guess I’ll go for the 25 frames then. Oh dear.
    >>If you had realistic hopes for both North America and Europe, I would have recommended a frame rate of 23.976<<
    Hm, that happened before, but I’m not sure if this would happen again. I think, in case they want the film, I’ll have some fun converting it. 🙂
    What I like even more than frame rates is the pixel ratio 😉 Yay, squash and stretch.
    Dave, I appreciate your help. Thank you very much!
    I’ll get back to work and let you know how this frame shift issue reacts to 25 frames.
    Best,
    Katherine
    November 18, 2009 at 8:58 pm
    I now got rid of the “Auto” Framerate in the project presets to 24 (I haven’t started switching to 25 yet). Then I reboot AE and made a new composition and copy-pasted the layers in it (which I tried before), and it worked now! Cool. This might have done the trick. But with the pingpong-problem (see https://forums.creativecow.net/readpost/202/884005), unfortunately the trick did not work out. Well, I’ll keep on trying to find out a solution.
