Frame / Sample Rate Mismatch in FCP ?
This problem has come up a few times recently.
A quicktime file plays back properly in quicktime or vlc.When imported into FCP it retains the same length, and the audio plays back fine, but the video seems to be slowed down (and is therefore cut off early in order to fit the original length of the clip). This also creates an audio/video sync problem.
This has happened with clips using a variety of codecs (DV, Uncompressed, Apple Pro Res) and export methods, but doesn’t happen to all clips. A simple transcode to a new format does not fix the problem.
I am thinking that FCP must be misinterpreting the frame or sample rates of these files, though I’ve tried transcoding to different sample rates without success.
We are using FCP 6.0.6 on a MacPro (2) Core2 2.66GHz 4GB RAM running OSX 10.5.8
