Activity Forums Adobe Premiere Pro Frame rates when outputting to 59.94 and 50
  • Frame rates when outputting to 59.94 and 50
    Posted by Ceri Allen on September 2, 2022 at 9:27 pm
    Hi
    I am editing in premiere pro using stock footage (so a whole bunch of different frame rates, so far I’ve seen 25, 60 and 29.97 and I’ve barely looked through it all) and GFX I will create in after effects.
    I have to deliver the films as Prores422.mov, 1080i, 59.94fps and also another version as 50fps. Normally I would work in the settings that I need to deliver in, but in this case I’m not so sure.
    Advice on what frame rate to edit and create my motion GFX in, and then how I would convert to the delivery specs?
    Ceri Allen replied 4 years ago 1 Member · 0 Replies
  • 0 Replies
