Activity › Forums › Adobe Premiere Pro › Frame rates and audio/video sync in Premiere 6.0
  • Frame rates and audio/video sync in Premiere 6.0
    Posted by Rick Larose on December 13, 2005 at 12:31 pm
    For some reason, a small number of my larger video files (3.4 gigabytes or so) were captured at 29.96 fps instead of 29.97 fps. So of course after exporting into a movie at 29.97 fsp, I’ve found the audio to be slightly out of sync after about the ten minute mark or so.
    1.Is there any way to fix either the original file or the exported movie clip (about 18 min. long)?
    2. Why did Premiere 6.0 capture some of my video files at 29.96 frames per second in the first place?
    Rick
    Tim Kurkoski replied 20 years, 9 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    December 13, 2005 at 6:03 pm
    You’re using a Canon video camera. Premiere 6.x has this problem with some Canon cameras because Canon does some funny things when it reports the frame rate information off the tape. It’s a pretty well known problem, and Adobe has a workaround available:
    https://www.adobe.com/support/techdocs/322232.html
    You will need to recapture all of your video that’s at 29.96.
