Activity › Forums › Adobe After Effects › Frame Rate Questions
Posted by Maverick Mooney on June 22, 2012 at 8:15 pmOkay, so say i have footage that is 200 FPS, My after effects only handles 99 FPS or so it says, is there a way i can set up after effect to handle these framerates?
Angelo Lorenzo replied 14 years, 3 months ago 2 Members · 3 Replies -
Angelo Lorenzo
June 22, 2012 at 8:38 pmIs this your playback rate or are you trying to make highspeed footage slow motion? I assume the latter?
Angelo Lorenzo
Fallen Empire – Digital Production Services
RED transcoding, on-set DIT, and RED Epic rental services. -
Angelo Lorenzo
June 23, 2012 at 5:17 amNot going to happen with After Effects or Premiere, at least in any way I can see.
Do what you can, try 60fps and work knowing the images are in “slow motion”, export out straight images instead of a video file and then feed it to something like FFMPEG for the final render. You might be able to get away with a frame rate that high.
As to why you would want to, the bottleneck will be your display/projector.
Angelo Lorenzo
