Activity Forums Apple Final Cut Pro Legacy Frame rate issue
  • Frame rate issue
    Posted by Benn Gunn on November 9, 2006 at 5:58 pm
    I have two uncompressed quicktime files which I have captured through my Black Magic card that ar playing havok with FCPHD.
    I have captured the footage at uncpmpressed PAL as I normally would to encode for DVD or to trim in FCP. However I am now finding that when I export my file using quicktime conversion I end up with an incompatible frame rate of 24.38 fps. I obviosly cannot use this type of file and I have no idea why this has started happening!
    I assume someone has changed a setting and not told me but in the meantime I cnat get around this problem.
    Any suggestions?
    Benn Gunn replied 19 years, 10 months ago 2 Members · 2 Replies
  • Aaron Neitz
    November 9, 2006 at 6:48 pm
    Why are you using Quicktime Conversion? What Codec are you going to? Where are you seeing this false frame rate (QT player?)
  • Benn Gunn
    November 13, 2006 at 12:14 pm
    I’m outputting using quicktime conversion so that I can set my compression to ‘None’. I then encode using Cinema Craft SP and it’s there that it cant decide what the frame rate is. When I view the quicktime itself it plays ok but the frame rate in the movie info is incorrect there too.
