Activity Forums Adobe After Effects frame rate in after effects
  • frame rate in after effects
    Posted by Corinne Bance on January 12, 2009 at 7:18 pm
    Hello ,
    I think I can remember ther is a way to change the frame rate on a layer but not in the composition. my aim is to give a “stop motion” aspect to a video. Do you have any idea ?
    Corinne
    Scott Geersen replied 17 years, 8 months ago 3 Members · 3 Replies
  • Kevin Camp
    January 12, 2009 at 7:43 pm
    there are two ways i can think of:
    1. precomp the animated layer(s) and set the comp settings (for the new precomp) to the desired framerate and then check the option in the advanced comp settings for preserve framerate when nested.
    2. precomp the animated layer(s) and apply the posterized time effect and set the frame rate in the effect to the desired frame rate.
    note, if the layer is a video layer, you can just use the posterize time effect without precomping.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Corinne Bance
    January 13, 2009 at 9:13 am
    thank you. I was looking for the posterize time effect but I couldn’t remeber the name. so thanks again
  • Scott Geersen
    January 22, 2009 at 12:31 am
    as a side note, posterize time as an expression in cs4 does not appear to work as it did previously in cs3.
