Activity Forums Adobe After Effects Frame rate conversion
  • Frame rate conversion
    Posted by Nicobeltra on November 20, 2006 at 10:12 pm
    I’m trying to convert a stop motion short film 1280*720 24fps to 720*486 30fps.
    Where in the render settings i can do this in AE7 ?
    Nicolas Beltra
    Nicobeltra replied 19 years, 10 months ago 2 Members · 4 Replies
  • Jonathan Miller
    November 20, 2006 at 11:31 pm
    In the render que click on the Render Settings to bring up the dialogue box. In there, under “Time Sampling” is a drop-down menu for Field Rendering. Since your comp will be 24fps (or 23.98), you’ll want to add 3:2 pulldown to bring it up to 30fps (29.97). Turn Field Rendering to Lower, then enable 3:2 pulldown “WSSWW. Check the right side of the window in the Frame Rate box to verify that the radio button labeled “Use this frame rate: 29.97” is selected.
    You should be good to go.
    Jon
    TreeLine Productions
    Fort Collins, CO USA
    Currently producing these popular podcasts:
  • Nicobeltra
    November 21, 2006 at 4:10 pm
    Thanks, only one more question, in the output module, wich is the right setting
  • Nicobeltra
    November 21, 2006 at 5:15 pm
    Thank you very much Jon I’ll try that.
    This is porpouse of the forums,
    thanks a lot again.
  • Nicobeltra
    November 21, 2006 at 5:18 pm
    I’m just mildly surprised that you’re asking this sort of thing comparatively late in the game.
    thank you a lot, a lot
