Activity Forums Adobe After Effects Frame rate conversion
  • Frame rate conversion
    Posted by Yoshiko Tanaka on February 10, 2022 at 4:04 am
    I have an AE project with several 50fps comps. I need to put them together to create an edit but in 24fps. What would be the best way to approach it?
    I know this has been asked many times in the past but they are all from nearly 10 years ago and I want to see if there has been a better process.
    Thanks a bunch in advance!
    Yoshiko Tanaka replied 4 years, 6 months ago 2 Members · 2 Replies
  • Tomas Bumbulevičius
    February 11, 2022 at 2:52 pm
    Hey Yoshiko, do you need to worry about perfect timing, when it comes to frames mismatch here and there because of conversion?
    Also, how many comps do you have there and would you need a batch-process for it?
  • Yoshiko Tanaka
    February 11, 2022 at 3:53 pm
    It doesn’t have to be perfect but I would like to avoid blurred images as most of the comps are bold shape layer images. I have about 50 comps.
