Activity Forums Adobe After Effects Frame rate confusion
  • Frame rate confusion
    Posted by Brendan Cave on February 12, 2010 at 4:30 am
    Hello all, I’m exporting animations from a 3D app and adding it to my After effects composition which I’m then rendering in order to A) be burnt to HD DVD (1280×720) and played on a TV and B) Put on a USB stick to be played by individuals on home computers.
    My questions are:
    At what frame rate do I render my 3D animation?
    What frame rate should my AE compositions be?
    At what frame rate should the whole project be rendered for the DVD and for the USB stick?
    I have to do this all tomorrow! Any insight will be very much appreciated.
    Brendan Cave replied 16 years, 7 months ago 2 Members · 2 Replies
  • Walter Soyka
    February 12, 2010 at 1:19 pm
    [Brendan Cave] “Hello all, I’m exporting animations from a 3D app and adding it to my After effects composition which I’m then rendering in order to A) be burnt to HD DVD (1280×720) and played on a TV and B) Put on a USB stick to be played by individuals on home computers. “
    HD DVD is a dead format — did you mean standard definition 16:9 DVD, or high-def 16:9 Blu-ray?
    You’ve got a couple choices on frame rates — what video format do you want to target? What kind of TV will play the footage?
    Where are you located? If you’re in the US, you can work with Blu-ray at of 23.976, 24, or 29.97 frames per second. DVD can do 23.976 or 29.97 frames per second. It won’t make much of a difference to the computers, but I’d probably lean towards 29.97, as it’s much closer to an even divisor of the most common display refresh rate (60 Hz).
    Walter Soyka
  • Brendan Cave
    February 13, 2010 at 1:50 pm
    Thanks Walter. Yeah, the DVDs seem to be playing fine. But the client is complaining of choppy playback on the computer (from a 25 fps .MOV file) Is there another reason this would be happening? Or will the 29.97 fps to fix this?
