Activity Forums Apple Final Cut Pro Legacy Frame Rate Change Messing Up Clip
  • Frame Rate Change Messing Up Clip
    Posted by Jason Smart on January 9, 2008 at 7:22 pm
    Okay, I filmed on the DVXB at 24pa and captured with the pulldown setting. When I watch the clip in Quick Time it shows the frame rate at 23.98 which is what I want. When I import the clip into final cut it shows the frame rate as being 29.97 so now when I play it back within Final Cut the video is sped up but the audio is at the correct rate. Any suggestions?
    Thom Obarski replied 18 years, 8 months ago 2 Members · 1 Reply
  • Thom Obarski
    January 9, 2008 at 9:09 pm
    Did you capture in FCP or use another application?
    If done in FCP did you try running the DV-NTSC 24p (23.98) easy setup first?
    If all else fails have you tried the remove advance pulldown from the tools menu?
    Worst case scenario it was shot 24p but you could go back and recapture & edit @ 29.97, you already have the quality bump of having shot 24p, just deliver like video.
    Hope that helps
    ~Thom
