Activity › Forums › VEGAS Pro › frame rate
  • frame rate
    Posted by Thayalan Paramasawam on August 31, 2012 at 10:58 pm
    Good morning Sir,
    I am using video camera panasonic ac 160 to shoot videos.
    Stream
    Video:50fps progressive 1920x1080x12,avc
    audio 48,000 hz,stereo,dolby ac3
    i want to make blu ray,when i rendering the project,should i change the frame rate to 25 pal or use back 50 pal…..
    pls help me on this matter
    Thank You
    John Rofrano replied 14 years, 1 month ago 2 Members · 1 Reply
  • John Rofrano
    September 1, 2012 at 1:09 pm
    [Thayalan Paramasawam] “i want to make blu ray,when i rendering the project,should i change the frame rate to 25 pal or use back 50 pal…..”
    You should not change the frame rates on any of the Blu-ray templates. They are set to the standards that Blu-ray requires. Blu-ray does not support 50p so you must render using the 50i/25fps template.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
