Activity Forums Apple Final Cut Pro Legacy Frame of Black in between edits
  • Frame of Black in between edits
    Posted by Andrea Stewart on June 27, 2008 at 11:25 pm
    Does anyone else experience this?
    Whenever I move a clip around and attempt to place it directly following another clip, almost always FCP places it one frame later than the previous clip, resulting in a flash frame of black in between. The only solution I’ve found is snapping. But snapping isn’t always so smart in what it snaps to, so generally I leave it off.
    Any solutions out there? Or quirks I should know about?
    Thanks.
    Andrea
    Andrea Stewart
    Producer/Editor/Director – Owner
    Germane Creative LLC
    Jeremy Garchow replied 18 years, 2 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    June 28, 2008 at 12:38 am
    Cut your clip your moving (command-x), put your playhead on the clip you want to put the cut clip after. Hit the down arrow, hit paste (command-v).
    This is what snapping is for, by the way. Anything else and you are putting the clip right where you left it.
    Make sense?
    Jeremy
