Activity Forums Blackmagic Design Frame link – QT to DPX = GREAT, am I suppose to be able to do it the other way round?
  • Frame link – QT to DPX = GREAT, am I suppose to be able to do it the other way round?
    Posted by Justin Tan on April 11, 2006 at 1:03 pm
    As above…
    Has anyone done this before?
    I found that if I do a QT to DPX, open the dpx file in the “virtual drive” and edit/save it back, it is reflected in the QT…
    but if I replace the file with another file or create a NEW empty QT file via frame link and put DPXs in them, it doesn’t work…
    If i replace the mounted drive full with DPX files, the frame when viewing the QT will be black or no change.
    If I create a empty QT (clicking on framelink and setting the specs -IE 1920×1080 etc) then drag DPXs into the the new QT file (mounted as a drive), the files copy over, but the QT does not reflect the change – it is still 8MB/1 frame of nothing.
    DPXs are created output via shake
    I have tried 1920×1080 files and 1920×156 files none work…
    Anything I should know?
    Kristian Lam replied 20 years, 5 months ago 2 Members · 1 Reply
  • Kristian Lam
    April 11, 2006 at 11:16 pm
    Hi Justin,
    Can you send us a 1 or 2 of your DPX files?
    Kindly send them to: support[at]blackmagic-design.com
    regards
    Kristian Lam
    Blackmagic Design
