Activity Forums Apple Final Cut Pro Legacy Frame editing
  • Posted by Joe Schubert on March 7, 2011 at 6:44 pm
    I recently saw a film that was edited in Final Cut. I had a chance to listen to the editor speak. He mentioned a cut that he did for a scene that involved cutting out every other frame. Does anyone know how to achieve this?
    Andy Mees replied 15 years, 6 months ago 7 Members · 10 Replies
  • 10 Replies
  • Scott Sheriff
    March 7, 2011 at 8:07 pm
    Dave,
    With a lot of painstaking work. Many cuts. It took a long time.
    What, there’s not a plugin for that?
    Scott Sheriff
    Director
    https://www.sstdigitalmedia.com
    I have a system, it has stuff in it, and stuff hooked to it. I have a camera, it can record stuff. I read the manuals, and know how to use this stuff and lots of other stuff too.
    You should be suitably impressed…
  • Richard Herd
    March 7, 2011 at 9:03 pm
    Another cool trick is to cut the frames, select every other one, and drag them in front of the cuts-where-they-belong…make sense? It’s very nifty.
    Should be: 1.2.3.4.5.6
    Changes to: 2.1.4.3.6.5
  • Joe Schubert
    March 7, 2011 at 9:51 pm
    What?
  • Joe Schubert
    March 7, 2011 at 9:54 pm
    Hey that does sound cool!
    But part of the question (as small time as it sounds) is if there is a keyboard shortcut to select every other frame in a sequence.
  • Joey Burnham
    March 7, 2011 at 11:14 pm
    Nope. Just grab your blade tool and zoom in as far as you can. Click away.
    Joey
  • Michael Gissing
    March 7, 2011 at 11:23 pm
    Cutting every second frame sound like speeding the clip up to 200% and turning frame blending off no?
  • Michael Gissing
    March 7, 2011 at 11:39 pm
    Or write a macro.
  • Scott Sheriff
    March 8, 2011 at 12:27 am
    Dave,
    Shhhhh…. I just read about a script called dotheeditforme.
    Funny thing. This is something at least two of the linear systems I worked on could do without building a user key list ripple.
    Set the edit duration, then leave the number of frames (+ forward,- reverse) to skip in the scratchpad, and hit ‘auto-animate’. Voila’, skip frame animation is generated while you sit there enjoying your coffee and Snickers.
    Scott Sheriff
    Director
  • Rafael Amador
    March 8, 2011 at 2:27 am
    To get rid of one in two frames you only need to speed the clip up 200% and no Frame Blending.
    But you do not explain what you want achieve.
    You want just to get rid of the frames?
    Do you want to leave a hole/black on the place?
    Do you want to replace the frame?
    You can play with the Strobe and the Blink filters.
    rafael
    http://www.nagavideo.com
  • Andy Mees
    March 8, 2011 at 5:04 am
    That does not sound cool at all .. thats horrible. Like bad field order. YOMV.
