Activity Forums Adobe Premiere Pro frame by frame moving a clip. Where did that shortcut go in CS6?
  • frame by frame moving a clip. Where did that shortcut go in CS6?
    Posted by Göran Thorén on May 28, 2012 at 7:03 am
    Hi all!
    I’m used to be able to move or nudge a clip in the sequence frame by frame simply by holding the cmd key and using my left/right arrows.
    And now in CS6 that doesn’t work?!
    Trying to make a new keyboard shortcut for it but I don’t know what that command is called!
    Anyone knows?
    Walter Tabax replied 10 years ago 5 Members · 5 Replies
  • Peter Garaway
    May 28, 2012 at 7:55 am
    Hi Goran,
    This still works in CS6. It’s called Nudge Clip Selection. Cmd+Left will move the clip 1 frame. Shift+Cmd+Left will move the clip 5 frames.
    Peter Garaway
    Adobe, Premiere Pro QE
  • Göran Thorén
    May 28, 2012 at 8:19 am
    Hmm.. strange that this doesn’t works for me, still works in CS5.5 thought…
    I’ll see if I can find that command in the keyboard layot and change it somehow.
    Thank’s Peter!
    /Göran
  • Joe Weber
    August 29, 2012 at 9:22 pm
    It’s called the nudge command and the default is Cmd + Left/Right Arrow for 1 frame or Cmd + Shift + Left/Right Arrow for 5 frames. If you are using the FCP 7.0 keyboard, swap Option for Cmd.
  • Curt Story
    June 7, 2013 at 9:28 pm
    Yeah–same here. I’m in Win7 and CS6, but I do alt + >, alt + < to move a clip a single frame forward/backwards or shift + alt + >/< to move 5 frames at a time.
  • Walter Tabax
    August 16, 2016 at 10:07 pm
    and if I want to move (nudge) a specific number of frames, like FCP where I only write “+1122” and the clip nudges 11 seconds and 22 to the right, or with minus signal: tor the left. Easy, not?
