Activity › Forums › Adobe Premiere Pro › Frame By Frame Editing
  • Frame By Frame Editing
    Posted by Max Jasso on August 18, 2009 at 5:37 pm
    In Premiere Pro I am supposed to be able to open a screen where I can delete frames, one by one,if neccessary. For accurate editing there seems to be a problem with frame editing. I went to the Adobe site, and they show a screen capture, where I should be able to delete singular frames, for some reason, I am just unable to do that. How do I open that screen? P-l-e-a-s-e, any step by step instructions would be great. Thank you so much,,….Max
    Jim Hines replied 17 years, 1 month ago 3 Members · 2 Replies
  • Phocas Kroon
    August 18, 2009 at 8:20 pm
    Maximize the timeline.
    Put the playhead on the frame you want to remove (check this with the frame foreward or backward key of the monitor.)
    Make a cut with the razor tool and delte the frame.
    Good luck
    Phocas Kroon
  • Jim Hines
    August 18, 2009 at 11:41 pm
    Are talking about the “Trim” window? If so hit the T key.
