Activity Forums Apple Final Cut Pro Legacy frame blending, reverse motion, field shifting, and thou…
  • frame blending, reverse motion, field shifting, and thou…
    Posted by Bob Flood on July 13, 2006 at 3:10 pm
    Hi
    working on a dv timeline w dv footage. took a clip, ran it backwards, the clip got soft. dropped shift fileds filter on it, the clip got sharp, BUT when i rendered the clip it got soft then i shut off shift fileds, clip got sharp again BUT when i rendered it for the second time, the clip got soft again!!
    sooo, with rt playback (no render) the clips looked ok, but when i rendered they looked soft
    after searching this forum, i tried shutting off frame blending. Now the clip plays sharp in real time AND when rendered
    any ideas, comments, or criticisms?
    bee eph
    2.7 G5
    kona lh
    fcp stu 5.0
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
    Bob Flood replied 20 years, 2 months ago 2 Members · 2 Replies
  • John Pale
    July 13, 2006 at 3:20 pm
    Frame blending, by definition softens the image. With many types of images its helpful…a necessary tradeoff to achieve a smoother slo mo. It’s not good for every type of shot, which is why you can turn it off. It’s processor intensive, which is why it requires rendering. Not sure what you are asking.
  • Bob Flood
    July 13, 2006 at 3:50 pm
    just asking if what i found made sense ie the difference between real time and rendered and how frame blending affected it
    Bob Flood
