Activity Forums Blackmagic Design Frame Accuracy (or lack of it) on edit to tape in FCP
  • Frame Accuracy (or lack of it) on edit to tape in FCP
    Posted by Mark Lediard on February 22, 2007 at 12:11 pm
    Hi there,
    Having a recurring and intermitant problem with Edit to Tape in FCP 5 across 5 different G5 systems and a selection of decklink cards. Our digital cuts are (around half the time) a frame late when editing to our DVW A500P. All our systems and the deck are genlocked to the same source and all are running on the latest BM drivers with FCP 5.0.4.
    This is a frustrating problem that is costing us a lot of time in re-starts and deck time. I understand that this is also a problem that has been encountered before, however, I can’t find any posts concerning a possible fix. I really need to know if this is a problem with FCP, Decklink or our video setup.
    Thanks in advance for any help
    Cheers
    Mark
    Mark Lediard – Transmission Post Production
    Sean Lander replied 19 years, 6 months ago 6 Members · 6 Replies
  • Jason Levy
    February 22, 2007 at 10:01 pm
    Can’t say but we occasionally get this too. Sometimes it goes away for a long time and then it’s back. Another funny thing.. sometime the audio is out of sync by one or two frames. We can tell because the beep and “2” are not lined up.. this mastering to a Digibeta via SDI? How can the sound go out of sync? a mystery. Costs a lot of time.
    Jason
  • Kristian Lam
    February 23, 2007 at 3:24 am
    Hi Mark,
    Please try the v5.6.2 driver as that is the last non-universal binary driver for use with Final Cut Pro 5.04.
    regards
    Kristian Lam
    Blackmagic Design
  • Guillaume De champs
    February 25, 2007 at 8:38 pm
    You might need to calibrate the timecode offset (in FCP, Device Control Preset tab).
    In this case, ensure capturing a clip with (reliably*) burnt-in timecode. Open the clip in the viewer, note the offset between the clip’s tc and the burnt-in tc and set the appropriate offset in the Device Control Preset window. Save the preset, and remember that this offset is only valid for this computer/this deck.
    *you may record a test with the superimpose out on the DVW A500P, and reconnect to the normal out when done.
    Hope this helps.
    Guillaume
  • Jeremy Brettingham
    February 27, 2007 at 9:55 am
    I’ve had this similar madening problem too – fiddling with the Device Control Pre-set (altering frame delay in playback) & also always using Edit to tape rather than Master seem to be the work-arounds. I’m using 8 Bit to Digitbeta & Declink HD btw.
  • Mark Lediard
    February 27, 2007 at 11:09 am
    Hi Jezza,
    Thanks for your reply. Specifically what setting re: frame delay have you used? I’d be very grateful if you could let me know
    Cheers
    Mark
    PS. I am pursuing some of the other soloutions suggested in this thread and will try and let you all know what worked when I figure it out.
  • Sean Lander
    March 2, 2007 at 2:19 pm
    I think you’ll find the 5.6.2 drivers will solve the problem. It did for us.
