Activity Forums Adobe After Effects Fractal Noise Only 5 Seconds
  • Fractal Noise Only 5 Seconds
    Posted by Thatsgreat2345 on November 19, 2007 at 3:12 am
    I was bored making a star filled sky. So I used the DIN plugin to make some random dots all over the place. I then used the Fractal Noise – Smoke Drifting. It only lasted 5 seconds though. The composition length was 7 seconds. Just curious how to extend it the full length of the composition?
    Darby Edelen replied 18 years, 9 months ago 3 Members · 2 Replies
  • Richard Harrington
    November 19, 2007 at 6:18 am
    Keyframe the Evolution property
  • Darby Edelen
    November 19, 2007 at 10:42 pm
    [thatsgreat2345] “I then used the Fractal Noise – Smoke Drifting. It only lasted 5 seconds though.”
    The animated keyframes will be at arbitrary points whenever you use Animation Presets that have keyframes. In the case of the Smoke Drifting preset it sounds like the Evolution property only animates from 0;00 to 5;00. Select the layer you applied this preset to and hit ‘u’ to reveal animating properties, then find the Evolution property and move the last keyframe to the end of your composition. You may also want to increase the value of the last keyframe since you are increasing the duration of the animation (same change in value / larger period of time = slower rate of change).
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
