Activity › Forums › Adobe After Effects › Fractal noise following an alpha obstacle ?
  • Fractal noise following an alpha obstacle ?
    Posted by Kilian Le dantec on November 18, 2016 at 4:56 pm
    Hi !
    So I’ve tried to do that for 3 days now.
    I want to do an opening title sequence, where there’s a moving “Rorschach Test” design, that transforms to a shape. So I use fractal noise, mirror it, but I can’t find the option (if it exists) to make my noise being influenced by a shape.
    The solution is not to simply use an alpha mask, because if I do that, the edges are straight lines, and I would like it to have the same edges as the fractal noise. There’s a similar option of what I’m looking for, with the Generate>Advanced Lighting. You can tick a box called “Alpha Obstacle” and the effects will follow the shape or avoid it, without being fully stopped.
    image 1 : My current result, we can see the edges of the shape are sharp. (There are two instances of fractal noise here : one in the middle, with the circle mask, and one all around it, with the same mask but set to substract)
    image 2 : a Video Copilot video where Kramer uses the alpha obstacle.
    Thanks a lot !
    Have a nice day
    (PS, if there’s no solution, if you have a trick up your sleeves to have the same effect, or know a plugin that can do that, please let me know) 🙂
    Michael Szalapski replied 9 years, 10 months ago 2 Members · 3 Replies
  • Michael Szalapski
    November 18, 2016 at 8:37 pm
    Use the Roughen Edges effect on your shape and crank the settings up so give you the look you need.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Kilian Le dantec
    November 18, 2016 at 9:23 pm
    That does it ! Thanks 🙂
  • Michael Szalapski
    November 18, 2016 at 9:35 pm
    You’re welcome! 🙂
    – The Great Szalam
